interference motor??
Anyone out there know if the 2003 2.0 L is an interference motor or not ? Timing belt jumped a few teeth,,
Yes it is.
Check for Engine Damage: CAUTION: This engine has been identified as an INTERFERENCE engine in which the possibility of valve to piston damage in the event of a timing belt failure is MOST LIKELY to occur. A compression check of all cylinders should be performed before removing the cylinder head(s). |
