How do you seperate the body from the chassis?
Old May 12, 2009 | 09:04 PM
triathlonx13's Avatar
Default How do you seperate the body from the chassis?
1970 Bug. All the "body bodys" are all removed. How do you seperate the body from the chassis ????
Old May 18, 2009 | 04:18 AM
cplthomas's Avatar
You might want to consider looking into the 'bug me' videos.. very informative.
Once all the bolts are removed its as simple a lifting it off. You might need to pry in certain areas as there is a sealant there. Also there are a few bolts in places you might not think.
Old May 20, 2009 | 01:27 PM
We got the body off. Yes the were a many areas that had a sealent in between the body and the floor pan. We had to use a flat chisel of sorts to pry / scrape away to free the body - so it could be lifted off.
Thanks for you reply.
paul69
Jan 17, 2014 09:08 PM
Jul 31, 2010 12:27 PM
kjmbruteforce
Jul 6, 2009 01:53 PM
Chris Angelo
Aug 24, 2007 04:50 PM
passat32awd
Dec 23, 2006 05:15 PM
