Help !Cylinder 3 & 4 Plugs fouling
Old Jun 11, 2008 | 04:45 PM
bobinheber's Avatar
Default Help !Cylinder 3 & 4 Plugs fouling
I have a VW powered trike. It is new last year (2007). After 2,000 miles I had some torsion work done (it was leaning) and had the valves adjusted and the heads torqued. That's when my troubles began. Cylinders 3 & 4 plugs are fouling. They are dry (not oil) but lots of carbon which from what I've researched, indicates that they are not firing properly. Because it is only on the 3-4 side that it is not carburetion otherwise it would be affecting all of the plugs. Anyone got any ideas ?
Old Jul 16, 2008 | 06:13 PM
bobinheber's Avatar
Default RE: Help !Cylinder 3 & 4 Plugs fouling
I found the answer from an old bug expert. I'll share it if you're interested.
Old Jul 16, 2008 | 07:48 PM
Jrailer's Avatar
intake boot or valve adjustment?
Old Jul 16, 2008 | 07:53 PM
bobinheber's Avatar
fuel pump gasket missing (some dummy left it out, oh yeah, that was me !). Add gasket-shorten stroke of fuel pump-less gas at idle-fouling stopped. It's always the simple things.
Gm042894
May 1, 2014 11:50 AM
cutty
Dec 21, 2008 08:05 PM
emagdnim
Apr 22, 2007 02:41 PM
salerno50
Oct 29, 2006 09:24 PM
onecrazyfuq
Aug 27, 2006 01:56 AM
