Fuel Pump still running after shut off??
Old Oct 11, 2010 | 07:10 AM
piyush123's Avatar
Default Fuel Pump still running after shut off??
Ok so I have been searching throughout the site for other owners with the same problem. Im new to VW (and I love it!) so im still trying to learn as much as possible. Ive been a gearhead for years so im fine with the DIY part of mechanics. So im trying to figure this out on my 07beetle. It started a week ago, where i shut the car off and i can hear the fuel pump still running. Its not loud but i can hear the faint vibration from the tank. I ramped the car and sure enough it sounded like the in-tank pump. So i pull the fuse out from the cab and bam its off. My question (other than what ive read from the door prime) is if this is normal. It eventually shuts off but im paraniod its going to burn out the pump. ... so relay?? any help is greatly welcomed! oh and the car only has 35,000 miles on its 2.5
Old Dec 5, 2024 | 10:03 AM
FiremanL1's Avatar
Default Same issue with 2007 2.5 fuel pump won’t shut off
Originally Posted by piyush123
Ok so I have been searching throughout the site for other owners with the same problem. Im new to VW (and I love it!) so im still trying to learn as much as possible. Ive been a gearhead for years so im fine with the DIY part of mechanics. So im trying to figure this out on my 07beetle. It started a week ago, where i shut the car off and i can hear the fuel pump still running. It’s not loud but i can hear the faint vibration from the tank. I ramped the car and sure enough it sounded like the in-tank pump. So i pull the fuse out from the cab and bam its off. My question (other than what ive read from the door prime) is if this is normal. It eventually shuts off but im paraniod its going to burn out the pump. ... so relay?? any help is greatly welcomed! oh and the car only has 35,000 miles on its 2.5
I’m having the same issue have you had any new findings on this problem? I’ve pulled relays and fuses with no fix.
Old Dec 5, 2024 | 09:27 PM
FiremanL1's Avatar
Default Issue solved 2007 2.5 VW Beetle fuel pump relay
So I spent a good portion of my day tracking down any professional knowledge about the fuel pump relay for my 2007 VW Beetle 2.5 that wouldn’t shut off. No one even at VW dealerships could tell me about the relay I was looking for with 8 pins with the number 409 ( 1J0906383C) 3DZ (8310009030) 12V 40A Well after a very frustrating day I took a chance with the 7 pin which worked and shut off the fuel pump perfectly. The part number I ordered through o’Reilly’s auto parts was 25-0235 1J906383C made by Import Direct OE replacement parts. I hope this helps anyone with the same problem as I had.
huyuhy
Jun 20, 2011 03:28 AM
ewin0014
May 15, 2011 02:14 PM
bobbygouge
Sep 21, 2008 07:48 PM
blackedout01
Jan 5, 2007 10:28 PM
JDUB
Jun 8, 2006 06:19 PM
