front end question
Old Feb 24, 2006 | 04:31 AM
...jasper...'s Avatar
Default front end question
Was wondering if anyone ever installed a fiberglass front end on a bug. Like a 1 pc. tilt
How was it ? and were did you get it ? Thanks ?
Old May 19, 2006 | 11:21 AM
MarkMcDaniel's Avatar
Default RE: front end question
Most of them are fairly easy to install. The big thing is getting a quality piece of glass that is made so that it will fit. There are a lot of crap pieces out there so beware. Don't buy one unless you can visually inspect it first for thickness and reinforcement areas. Edges should be about twice as thick as flat areas and mounting points as well as pressure points should be reinforced.
Depending on where you live in relation to where the manufacture is is another consideration. I just priced a baja kit from Mark 5 fiberglass in Nevada. The kit cost was $365, shipping would have been between $350 and $400. They normally provide a quality product but with those shipping charges I decided not to place the order.
doubleroost
Jan 7, 2009 08:11 AM
Fradonson
Jan 28, 2006 02:46 PM
neturbo82
Aug 22, 2005 02:32 AM
neturbo82
Aug 22, 2005 02:28 AM
low04gix6
Apr 15, 2005 03:57 PM
