Clunking sounds from driver side rear tire
Old Apr 1, 2008 | 10:36 AM
cory's Avatar
Default Clunking sounds from driver side rear tire
I have a 1968 bug with a bugatti fiberglass kit on it. When driving at any speed the driverside rear tire clunks. The clunk sppeds up as the car speeds up so i thought it might be the bearing but I took a look and the bearing looks fine. Any suggestions of where to look next???
Old Apr 11, 2008 | 03:18 PM
cory's Avatar
Default RE: Clunking sounds from driver side rear tire
Wow 51 veiws and no replies. Does anyone know about cars on this forum?? Please help me out!
Old Apr 12, 2008 | 01:06 PM
bagel's Avatar
No one replied prolly cause they don't know about '68 bugs. I know less than zero about '68 bugs, but a front end noise has something to do with the suspension. You checked the wheel bearings right? Becuase these cars are rear motor/rear drive, there maybe an axle going bad or something. Other than that, I don't know I'd have to look into it and do some research.
Old Apr 12, 2008 | 01:17 PM
knightrs32's Avatar
Oh, come on bagel, several of us know about the old bugs, there are just some problems that elude us!
Mine does the same thing, but on all four corners. I'm still searching...
Old Apr 12, 2008 | 01:22 PM
bagel's Avatar
I'm not taking anything away from anyone on here; would it have sounded better if I said n o one replied cause they didn't want to? Anywyas, I'll look, too.
Old Apr 12, 2008 | 06:28 PM
cory's Avatar
Hey don't worry about bagel I found a forum where people acually try and help out.
Thanks for the help knightrs32!
Old Apr 12, 2008 | 06:42 PM
  #7
pimemtel's Avatar
Member
Cory can you pm me with the forum.
thanks
Old Apr 12, 2008 | 10:05 PM
  #8
Jrailer's Avatar
how did you pull the bearing without pulling the axle tube?
or did you just look at the bearing
they dont go bad that often on swing axle trans
possibly a drum starting to stripout
Sorry i have been helping other people didnt see your topic untill today
Old Apr 12, 2008 | 10:17 PM
  #9
Jrailer's Avatar
i have seen when people put to long of wheel studs (lug bolts)in and they hit the wheel cylinder or brake hardware
Old Apr 15, 2008 | 03:08 PM
  #10
cory's Avatar
Yea I think that I got it figured out after all that work it was just the wheel spacer. thanks to those with advise.
richmaier
Sep 17, 2013 11:10 AM
paulclark51@live.com
Apr 4, 2011 04:19 PM
VWblackPolo
Sep 8, 2010 06:17 AM
gizmo00
Mar 31, 2008 01:54 PM
redbuggy
Nov 28, 2006 03:15 PM
