Bad Brakes
Old May 21, 2006 | 12:30 PM
danlewi's Avatar
Default Bad Brakes
I have a mystery I've been trying to solve with my brakes that has been going on for several months. Back in the fall I replaced the master cylinder on my 73 super. Within that time I have also replaced all the wheel cylinders. After replacing the leaky master cylinder and much bleeding I would find a small amount of air in the master. However, I have lost NO fluid. Is it possible for air to be coming from the resevoir somehow? This being the low pressure side of the system I haven't really considered it having a significant effect in this dilemma. Any ideas?
Old Jul 12, 2006 | 01:40 AM
Springer's Avatar
Default RE: Bad Brakes
When you installed the master cylinder, did you bleed the air out of it on the work bench before installing it onto the car?
Old Jul 14, 2006 | 03:24 PM
danlewi's Avatar
No, I hadn't bled the master and I've wondered if that's the source of my frustrations. I'll have to go to the auto parts store and invest in a bleeding kit for the master. Unfortunately, this is my daily driver, so I haven't had much opportunity to tear it down or the help to bleed the system. I drive it a short distance to work, so I've learned to tolerate it 'til that time, but I won't suffer anyone else to drive it 'til it's fixed. Thanks for the advice!
JurassicWarrior
May 27, 2008 10:51 PM
moe.ron
Dec 2, 2006 01:24 PM
klugej
Jul 11, 2006 12:01 PM
klugej
May 11, 2006 01:23 PM
fdunne
Jan 13, 2006 12:35 AM
