65 Beetle Drive Belt Broke!
Old Aug 10, 2008 | 10:48 AM
nirahlee's Avatar
Default 65 Beetle Drive Belt Broke!
I purchased a '65 beetle yesterday and on my way home the drive belt broke! I stopped the car immediately and replaced it, however, the engine got hot - it was smoking!
Afterwards I could not get much power our of the car - I could only get up to about 40mph tops! I'm new to the air-cooled engines. Can you help me with what I should start checking to find the problem? Thanks,
Harin
Old Aug 10, 2008 | 12:17 PM
Jrailer's Avatar
Default RE: 65 Beetle Drive Belt Broke!
have the heads retorqued and valves adjusted
Old Aug 13, 2008 | 08:42 AM
nirahlee's Avatar
OK, when I removed the valve covers one of the valve springs was stuck down. When I would pop it back and rotate the engine by hand it would get stuck again. So when I removed the rocker arms I just turned the spring a few times and now that problem seems to be gone.
I tightened the head bolts to 23 ft-Lbs but the engine still has no power. I'm not burning oil or leaking oil which I think is a good thing but I'm not sure what to do next.
Any ideas?
thanks!
Old Aug 13, 2008 | 06:10 PM
nirahlee's Avatar
Today I figured out that the #3 cylinder is not firing. This is the same one that I had the stuck valve-spring on. The spark plug had oil on it when I removed it. I'm guessing it's a leaky valve stem seal? But is that enough to cause the cylinder to not fire at all?
What else should I check before removing the head? Can I remove the head while the engine is still in the car?
thanks!
Harin
Old Aug 13, 2008 | 07:17 PM
Jrailer's Avatar
#3 is the first one to overheat might have burnt a piston
Old Aug 15, 2008 | 07:39 PM
Jrailer's Avatar
its a 65 bug nota newer one only one coil and a set of points
briandownunda
Oct 27, 2010 06:57 AM
xmlabh
Jan 9, 2009 08:40 AM
74superblue
Aug 1, 2007 10:02 PM
98vert6spd
Jun 1, 2007 01:21 PM
cody
Jan 1, 2007 09:08 PM
