2003 New Beetle, auto transmission woes...
Old Dec 14, 2009 | 01:19 PM
ManicMechanic's Avatar
Exclamation 2003 New Beetle, auto transmission woes...
Hi all,
My wife's Beetle has been shifting with a whiplash-inducing jerk for the past few months, and finally got stuck in third gear last week. It was suggested that I check the transmission fluid before spending thousands of dollars on a new transmission - so, with my handy Haynes guide in tow I researched it, figured that I could do it, got everything I needed including new fluid, new plugs, new filters, etc and got to work.
According to VW, the transmission case is a "sealed" system, and there's almost no way to access the fluid. You can unscrew a small bolt and check the level, and pop out another plug and fill the thing, but there's no easy way to do either. Get the fluid up to at least 95 degrees, take out the bolt, and if a few drops come out then the fluid level is correct. If it's not, you have to add a little bit at a time until the level is correct. To my knowledge (and I would know), the car has NEVER had its transmission fluid changed.
Now, I'm not a beginner mechanic; I've changed the timing belt and water pump on her car already, done all the brakes and oil changes, spark plugs, etc. I've also done nearly all the work on my car (Ford Escort) for the past seven years including changing out the bushings around the main drive shaft inside the engine, replacing the exhaust system, etc. I'm not a pro, but I know my way around an engine reasonably well. The only thing I haven't been able to handle is a complete rebuild of my automatic transmission.
I took out the check-level bolt, and brownish fluid started pouring from the small hole - nothing like the red of transmission fluid, it obviously needs to be changed - but here's the rub: I can't get the fill-plug out without forcing it, and I'm nervous about doing so. And, even if I get the fill-plug out, the access hole is nearly impossible to access. Lastly, I truly don't see how the Beetle can have 7.4 quarts of transmission fluid inside that one little pan.
Any advice would be extremely helpful. At this point, I'm ready to call AAA and have the car towed to the dealer, never to work on the transmission again.
Thanks in advance.
Tai
Old Jan 6, 2010 | 04:13 AM
assodia09's Avatar
Default 2003 New Beetle auto transmission woes
Now that China is ready to eclipse Germany in VW sales all is looking even better overseas for the company.
Old Apr 9, 2010 | 04:11 AM
kurtdaniel's Avatar
Member
yeah,,tow it to the dealer..they have good quality oem part there to replace your cars defective parts..
Old May 9, 2010 | 03:14 PM
kkaschke's Avatar
Default I feel your pain...
I have a 2003 as well and my valve body had to be replaced last year. Now my tranny totally quit. My delima is that the car is only worth $4500 and a new tranny will cost me that much. I'm leaning more towards selling it for whatever I can get and get a new VW that's not made in Mexico.
Old Jun 7, 2010 | 08:05 PM
ping_'s Avatar
Yellow stone diesel parts plant is one of the leading manufacturers
of engine parts, in particular diesel fuel injection system
accessories for replacement, such as Fuel injection Nozzle, Plunger and
Delivery valve, ETC In south of china .
for more detail please visit our website : www.yellowstonediesel.com
www.dieselinjection.cn
Yellow stone diesel parts plant was founded in 1997.Over the years,
Yellow stone has grown and gained a reputation for producing
high quality products and delivering them on time.
105015-5860
105015-5860
105015-5940
0 433 171 134
0 433 171 137
0 433 171 146
5611065 H60S30A538
5611650 BDL110S6133
5611735 BDL110S6267
6801082 6801082
6801087 6801087
6801088 6801088
DN10PDN130
DN0PDN121
HL176S27D525P2
2418455518 2455-518
2418455714 2455-714
9401087506 9087-506
134151-4120 P121
134151-4920 P129
134151-6420 P143
NOZZLE DENSO 093400-7690 DN10PDN129
NOZZLE DENSO 093400-7700 DN10PDN130
NOZZLE DENSO 093400-8220 DN0PDN121
131110-9320 131110-9420 131160-0320
harlyldude
Jun 7, 2011 04:57 PM
soscholz
Aug 4, 2007 04:35 AM
littlewhitedaisy
Jun 28, 2007 07:57 AM
peace007
Mar 22, 2007 02:48 PM
FSU2001rx
Sep 25, 2006 01:06 AM
