a weird clunk and then a pull!!!!
Old Aug 4, 2008 | 10:21 AM
ryno01's Avatar
Default a weird clunk and then a pull!!!!
i have a 01 gti with a manual tranny, i was turning left out of my street and i heard a lound clunk, but i just kept driving. the car seemed fin, then it started pulling hard to the left. i pulled over and it clunked again. idrove it home it was fine until i got to the house and it started pulling again. does anyone have any idea what this could be? could it be dif problems or cv problems?
if anyone has anything that would be awsome!!! thanks
Old Aug 4, 2008 | 04:24 PM
bagel's Avatar
Default RE: a weird clunk and then a pull!!!!
check the inner/outer tie rods....on both sides just ti be sure. Did one side of the vehicle sink down more than the other??
Old Aug 4, 2008 | 09:33 PM
ryno01's Avatar
the tie rod ends are fine. when the right tir is on the ground and the left off, and the tranny is in neutral the wheel should spin freely right? oh yeah and no the one side didnt sink. i think it might be my differential, cause pulled the drain plug and the fluid was a dark metalic color wich usually means a bearing or something has failed.
Old Aug 5, 2008 | 12:11 AM
Jrailer's Avatar
ouch!! sounds like a diff. did you check your cv joints?
Old Aug 5, 2008 | 09:46 AM
ryno01's Avatar
yeah the CV joints seem to be fine i think ime screwed!!!
Robert Eggleton
Apr 9, 2013 06:28 PM
Noland
Oct 22, 2009 06:09 AM
RecklessGhettoJetta
Aug 31, 2009 03:08 PM
jbm3
Jul 10, 2009 03:47 PM
bettyblue
Nov 20, 2005 05:48 PM
