Throttle body
Old Feb 22, 2006 | 03:28 PM
d_moser's Avatar
Default Throttle body
My throttle body keeps clogging with gunk and tripping the check engine light. Does anyone have any idea how to stop this and why it's doing it? The engine sputters a little and I want to give it a tune up, but if the throttle is mucking up the spark plugs, I need to solve that problem first.
Old Feb 22, 2006 | 04:20 PM
bagel's Avatar
Default RE: Throttle body
Get yourself some Gumout throttle body cleaner/spray. Spray it in, let the car run a minute or two, and see where you're at. Depending on what's all getting in there, wether it's blowby or what, you can rid yourself of the problem. I had some blowby on my Jetta, I went to put on a cold air intake when I first got it and noticed some oirl (better known as oil) sitting all inside the air box and hoses. I installed a catcher that collects all that blowby, like a reservoir, and hadn't had a serious problem at all. I've seen some use the same thing in fuel lines to catch water, I'm assuming. This is all I know....hope it helps some.
alooh2000
Jun 5, 2010 01:47 PM
fasteddie
Aug 10, 2008 07:58 AM
racerx002
Mar 12, 2008 07:51 PM
spyoptic01
Nov 9, 2007 05:10 PM
Pike101
Oct 17, 2006 03:45 AM
