question about 2275cc engine
Old 08-25-2008 | 08:20 PM
19tiny83's Avatar
Default question about 2275cc engine
I was wondering if a 2275cc vw engine would be reliable for street use on a sand rail? I plan on driving it on weekends and to work ocaisionally when weather permits didnt know if the engine would be to radical. The engine was proffesionally built and has dual 44 weber carbs. Thank you for your help.
Old 08-25-2008 | 09:46 PM
Jrailer's Avatar
Default RE: question about 2275cc engine
they run on the hot side from the pistons being so much closer together
you could turn the timing down a little to help it run cooler
Old 08-25-2008 | 10:08 PM
19tiny83's Avatar
Thank you for the help i am guessing a 1904cc with over 100hp would have the same problem?
Old 08-25-2008 | 11:06 PM
Jrailer's Avatar
not as bad
PassatGuy
12-23-2008 09:02 PM
wrbush31
11-29-2008 04:21 AM
nitro121
06-30-2008 11:35 PM
NCangler
04-22-2008 05:46 PM
ahsbball05
09-06-2007 08:02 PM
