I'm Stuck!
Old Oct 9, 2006 | 11:42 AM
saintPadraig's Avatar
Default I'm Stuck!
I am stuck on how to remove the steering lock/ignition switch assembly from a 1990 VW golf. (See attached photo) I’m taking parts from this car for my 1991golf)
The repair manual book is a little vague on this one. They say prise off the lock washer from the inner column and remove the spring and contact ring; then remove the lock assembly. However, if you look at my attached photo you will see a large thick sleeve that the steering wheel fits on, that would prevent removal of the spring. Does this sleeve need removing; and how - if it has to come off would I need a puller?
See attached photo
Please help if you can; much appreciated
Padraig
[IMG]local://upfiles/2202/1FA9D5D6799C49E19D8C3AFFBA155497.jpg[/IMG]
streetlights
Jan 14, 2021 01:50 PM
moe.ron
Dec 2, 2006 01:24 PM
skipdrag
Oct 29, 2006 08:57 PM
jhodor
Aug 20, 2006 10:48 PM
apercele79
Jul 12, 2006 01:35 PM
