DEF level
Isn't there an option on the MFD for radio/sat/nav settings? I think it just shows miles left not the level.
I did read what you wrote,
"You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out."
Why do I NEED to get my motor scanned? I don't have a problem that I am attempting to solve. I am simply inquiring if there is a method to determine the level of DEF in the tank other than waiting for the warning light to come on?
Will check the system out if there any bad sensors or any software updates in the sat/nav..
Question: "Is there a way to determine the amount of diesel exhaust fluid in the tank ?"
Acceptable Answers: 1. "Yes, and here's how you do it"
2. "No"
3 " I don't know, maybe someone else on this forum does"
2. "No"
Isn't there an option on the MFD for radio/sat/nav settings? I think it just shows miles left not the level. >Showbox jiofi.local.html tplinklogin
