code p0411
Old Jul 8, 2009 | 01:18 AM
grocerman2007's Avatar
Default code p0411
air pump seems to be working.
how do I trouble-shoot entire secondary air system
Old Apr 6, 2023 | 08:47 PM
JohnE's Avatar
Old thread, but I'll jump in anyway.
For starters, with engine and ignition off:
1) disconnect the vacuum control line from the combi valve
2) apply vacuum to it to open the combi valve
3) jumper across the pump relay to run the pump
4) feel for air flow coming out the tailpipe whenever the pump is run
With the engine running, check for vacuum/suction at the combi valve control line during a cold start when the pump is running. No vacuum there --> check the combi control solenoid valve that is tucked under the intake manifold. This was my secondary air system problem.
JimC
Aug 3, 2015 08:09 PM
ffarid109
Sep 7, 2014 01:47 PM
aaronfuzion
Jul 2, 2014 07:03 AM
enginedriver
Sep 4, 2012 05:34 PM
dieseljunkie12
Sep 17, 2008 07:46 PM
