Aftermarket Stereo Installation?
Old 07-10-2007 | 04:39 AM
corey_lynx's Avatar
Default Aftermarket Stereo Installation?
Hi, Im new and was thinking about puting an aftermarket stereo in my 2001 VW Beetle. Is there anything specialI should know, or any reason why I shouldn't do this? thanks for any help,
Corey
Also, what is Monsoon sound system and how doI know ifI have it?
Old 10-08-2007 | 12:23 PM
hobartt's Avatar
Default RE: Aftermarket Stereo Installation?
i have the monsoon in my 2000 jetta and when u turn on the stereo it should read it across the screen, and i believe it is just the better stereo system in vws
Old 10-13-2007 | 11:37 AM
tccdestroy's Avatar
the beatle is a pain in the *** car to install an aftermarket cd player, especially if it has the monsoon system. I would strongly recommend having it professionaly installed. There is a special adapter face kit you need for it and it is available at most stereo shops. The experiance i have with it, i would avoid a cd player with a motorized or flip down face, it tends to get jamed in the adapter plate....good luck
Old 04-02-2008 | 10:26 PM
newfonfire's Avatar
Hey
I replaced my stereo in my Jetta with an aftermarket one. On a trip at the mechanics, he told me that I shouldn't have done this because the VW stereo has a computer chip with a wire that sends a message to the computer. Doesn't sound like a huge problem to me. The aftermarket stereo is still there!
Old 04-02-2008 | 11:31 PM
Jrailer's Avatar
its not a chip but it does send a signal to the data link conector
sometimes this will make a non comunication with a scaner or code reader
i worked on a audi TT with a stock stereo that had the fuse blown on the back of it and it wouldnt comunicate for a emmision test
Old 09-18-2008 | 03:03 PM
mchawkins707's Avatar
If you put an after market stereo into VW you are going to disconnect a grounding wire from the "Y" connector which is attached to the stereo wiring harness. This will make it so that you can not get a proper reading through your OBD-II connector. That means that any time you want to hook your car up to a diagnostics machine, or a dyno... No go. You will get an error reading. If you are unfortunate enough to live in a state that requires a SMOG check to register the vehicle then the vehicle will not pass smog. I had all of these problems listed above a few weeks ago. It is a huge pain and not worth it at all.
  #7
Old 09-18-2008 | 07:17 PM
Jrailer's Avatar
not true i put a sony in my sons 98 beetle and every thing still works great i tested it after the install and it all still reads fine
you just need the install harness for it and follow the manual
crjb
03-01-2011 04:53 PM
GilNarmor
08-11-2009 10:47 AM
parkersgirl
02-21-2008 08:59 AM
ultramagnus
03-08-2006 02:48 AM
silverbullet1.8t
08-16-2005 05:59 PM
Quick Reply: Aftermarket Stereo Installation?
