85 vw wont start
Old Nov 18, 2004 | 11:50 PM
85 VW's Avatar
Default 85 vw wont start
k i have an 85 jetta that wont start it has power from the bat. but wont turn over
Old Jun 7, 2006 | 02:22 PM
stv fox's Avatar
Default RE: 85 vw wont start
check all connections and wire condition the battery may have 12 volts but low amps try a full charge with a bat charger then boost it as well.could be ignition swich is the key tricky to turn or worn out.check fuses is there any klicking sound when you turn the key that would mean power is getting to the starter but not enough amps need new batery.
GtflyRob
Jan 14, 2009 01:18 AM
Dewald
Dec 15, 2008 11:33 PM
20NA
May 9, 2006 06:11 PM
themechanic07
Jan 24, 2006 09:43 PM
white mk2 auto
Dec 2, 2005 07:47 PM
