2001 VW Passat V6 Wagon
Old Nov 5, 2008 | 10:40 AM
starfire6619's Avatar
Default 2001 VW Passat V6 Wagon
Hello.
I just purchased a 2001 VW Passat Wagon. V6, Automatic. It has 102K miles. I just has the tires replaced, front end alignment and a passenger side tie rod.
I still feel like there still is a shaking of the car and I can't figure it out. Not terrible, but noticable.I do not feel it is struts as that would be more noticable. More on thepassenger side of the car. If I look at my passenger seat, I see it shaking.
Any suggestions would be appreciated. I am not a mechanic and I do not want to be taken advantage of.
Thanks.
Old Nov 5, 2008 | 06:53 PM
dbaseballs's Avatar
Default RE: 2001 VW Passat V6 Wagon
what kind of tires did you buy?? did they balance them? and if they are generic brand tires they arent always as easy to balance as name brand tires, so you might feel that wobble or shaking in the steering, cause i have generic brand tire on the front and they shake a little bit
Old Nov 6, 2008 | 08:08 AM
I actually invested in good tires. A decent set of Michelins. I also had balancing and an alignment. I was wondering one of the following.
1. Does it need to be re-balanced?
2. Ball Bearings gone bad? or, Ball Joints?
3. Anything else that holds it in place.
Thanks.
Old Nov 6, 2008 | 10:34 AM
Jrailer's Avatar
upper controle arms
starfire6619
Nov 5, 2008 10:36 AM
RogueGambit
Aug 14, 2006 04:21 PM
archiethereal
Aug 8, 2006 09:26 AM
terrym
Jul 6, 2006 01:07 AM
cdmac517
May 16, 2006 12:23 AM
