2001 passat led instrument panel lights out
Old Nov 5, 2005 | 02:36 PM
passatmom's Avatar
Default 2001 passat led instrument panel lights out
I have a 2001 vw passat, the illumination lights for the instrument panel for the heater and fan controls is out. Is this a light problem or could I possibly have a fuse out? The indicator lights for the right and left vents are also out, any connection?
Thank You
Old Nov 5, 2005 | 06:37 PM
Jsd's Avatar
Jsd
Default RE: 2001 passat led instrument panel lights out
Pull your fuse panel and check the
fuses that are for the instrument lights
to see if they are burnt out. I doubt it's
a wire issue being a 2001. Just start
with checking the fuses and work your way
to the actual panel itself and check all the
connections.
Oct 29, 2010 02:41 AM
martinks_9
Jan 24, 2010 01:22 PM
MCJENSEN
Jun 7, 2009 06:06 AM
Mikeyman64
Dec 7, 2008 01:14 AM
Donna
Oct 28, 2007 12:01 PM
