1999 Golf - Heat issue
Old Jan 3, 2008 | 07:42 AM
rb6493's Avatar
Default 1999 Golf - Heat issue
Hi,
Dam cold here in CT. When outside temperature is above 40 degrees , thermostat stays at 190 all the time.
If any colder the thermostat stays down around 120, and if you use heater it goes lower.
Doesnt make for a very warm commute. Will never go above 140 even after 1 hr commute.
Any suggestions?
Thanks
Old Jan 5, 2008 | 05:44 PM
Smokin Dog's Avatar
Default RE: 1999 Golf - Heat issue
Sounds like you have a great cooling system. If it's working that good and nothing is wrong, you might play the
ole trucker game. Use a good piece of card board and slide
it in front of the radiator, but be sure it's only about 1/2
covering the radiator, then after you drive it you will be able
to tell if you need to cut the cardboard down smaller or get
a larger piece. just don't block off all the air flow and be
sure to watch the temp gauge for over heating.
viggo olesen
Mar 7, 2016 07:26 PM
ktktkt7
Dec 1, 2010 01:59 PM
Berrie
Nov 7, 2007 06:24 PM
flex2slick
Oct 12, 2007 07:45 PM
jeepwillies
Jan 25, 2007 05:24 PM
