1970 Beetle 1.6 will not accelerate or run smoothly
Old Apr 25, 2025 | 07:31 AM
HeavyEqptguy's Avatar
Default 1970 Beetle 1.6 will not accelerate or run smoothly
1970 Sun Beetle purchased in January ‘25
replaced all cylinders and pistons
sent heads to be cleaned/replaced valves (all valves adjusted to .006)
replaced fuel tank, all rubber hoses, filter and fuel pump
Replaced carb with 32/36 DFEV from Amazon (Weber clone)
Engle W100 cam
Replaced entire ignition from switch to coil to distributor to wires/plugs
Now for the problem…
Engine runs ok at idle…just OK…has the slightest miss/shake
Will not accelerate smoothly… occasionally backfires and/or bogs down during heavy acceleration
Good power at higher RPMs
It is driveable but is not quite right
Sethwp.23
Jun 13, 2017 08:12 AM
Tbyrd_77
Sep 13, 2010 02:20 AM
Boogsmom
Jul 28, 2010 04:44 AM
