13 Codes!!! Engine cut off before 1500rpm
Old Jul 23, 2006 | 01:06 AM
kupiec79's Avatar
Default 13 Codes!!! Engine cut off before 1500rpm
Hi guys.
Am a new owner of 1999 Passat 1.8T SW
I bought the car of ebay an had it deliver to me. ( 1st and last time i bought car on internet )
Here is my major problem with the engine:
When am trying to drive or just push gas pedal engine cuts off power before i reach 1500rpm.
Check engine light is on so i pulled the codes.
There is 13 !!!! of them. Here is the list
P1545 - Idle speed control
P1505
P1237 - Fuel air meetering
P1238
P1239
P1240
P0118 - engine control temp circuit high input
P0102 - MAF or VAF input
P1613 - axelary inputs/outputs
P1544 - speed control
P0123 - pedal possision low/high input TPS
P1425 - axelary emmision control
P1472
Please. I need your help. I assume it will be one or maybe 2 parts to exchange but looks expensive.
Give me some idea. I dont want to go to the dealer becouse they will overcharge me.
Old Aug 16, 2006 | 05:21 AM
emagdnim's Avatar
Default RE: 13 Codes!!! Engine cut off before 1500rpm
there has to be some sort of lemon law you can file.... that definetly doesn't seem right that the dead beat just screws you over with a pile of car...
Old Aug 21, 2007 | 09:14 AM
mercadoraul's Avatar
I thing your main problem is P1545. I own a 1999 sedan passat, 1.8turbo. I changed a used TPS, and aused ECU. When I replaced the TPS there was not change. After 4 months, I bought a used ECU also at ebay. It solved the problem for only one day, after thebattery came discharged, the same problem came. Computer from my mechanic showed P1545 code again. After 7 months from I bougth my car, it is working, thanks to Vag Com software. It could save me several problems. There is an TPS adaptation turning on the key, living it for 3 minutes, furn of key, and then run the motor; but is just solve the unistable of the notor.
You must run a basic TPS adaptation using Vag Com. Now, my car is able to run above 1500rpm. You could buy the interface cable for Vag Com from ebay (about $15Dollars) and the Vag Com license from www.ross-tech.com. The software price is $99 dollars. Good luck !
floridavwguy
May 13, 2011 01:25 AM
indy_jetta
Jul 15, 2010 10:16 PM
kenstar
Oct 22, 2007 04:28 PM
kupiec79
Jul 23, 2006 12:42 AM
2006TurboJetta
Jun 15, 2006 06:11 PM
