13 Codes!!! Engine cut off before 1500rpm
Hi guys.
Am a new owner of 1999 Passat 1.8T SW I bought the car of ebay an had it deliver to me. ( 1st and last time i bought car on internet ) Here is my major problem with the engine: When am trying to drive or just push gas pedal engine cuts off power before i reach 1500rpm. Check engine light is on so i pulled the codes. There is 13 !!!! of them. Here is the list P1545 - Idle speed control P1505 P1237 - Fuel air meetering P1238 P1239 P1240 P0118 - engine control temp circuit high input P0102 - MAF or VAF input P1613 - axelary inputs/outputs P1544 - speed control P0123 - pedal possision low/high input TPS P1425 - axelary emmision control P1472 Please. I need your help. I assume it will be one or maybe 2 parts to exchange but looks expensive. Give me some idea. I dont want to go to the dealer becouse they will overcharge me. |
RE: 13 Codes!!! Engine cut off before 1500rpm
there has to be some sort of lemon law you can file.... that definetly doesn't seem right that the dead beat just screws you over with a pile of car...
I thing your main problem is P1545. I own a 1999 sedan passat, 1.8turbo. I changed a used TPS, and aused ECU. When I replaced the TPS there was not change. After 4 months, I bought a used ECU also at ebay. It solved the problem for only one day, after thebattery came discharged, the same problem came. Computer from my mechanic showed P1545 code again. After 7 months from I bougth my car, it is working, thanks to Vag Com software. It could save me several problems. There is an TPS adaptation turning on the key, living it for 3 minutes, furn of key, and then run the motor; but is just solve the unistable of the notor.
You must run a basic TPS adaptation using Vag Com. Now, my car is able to run above 1500rpm. You could buy the interface cable for Vag Com from ebay (about $15Dollars) and the Vag Com license from www.ross-tech.com. The software price is $99 dollars. Good luck ! |
