need help asap
need help asap
ok i have a 2000 passat v6 last nite i was removing my trunk light because it went out, after that i closed my trunk and went to park my car in the garage but wen i tried turning it on it wouldnt the headlights turn on the dashboard lights turn on but my alarm doesnt lock or unlock. My interior lights dont work either. i checked my fuses and their all fine. I tried jump starting it but that didnt do anything either what can the problem be? plz i need help thnxz
dingoden69
dingoden69
Did you replace the trunk light? If you did, try resetting the ecu by disconnecting the battery cables and holding them together for a couple of minutes. That should work if you triggered a safety mechanism. Post in the Passat forum. This is for forum suggestions.
britney42100
03-05-2010 05:40 PM
