please help PO748
Old 01-21-2017, 10:13 AM
SirCasper1's Avatar
Default please help PO748
2004 Jetta we are getting a PO748 error code..... when we research it comes back the pressure solenoid .... can't find where that's located
Old 01-22-2017, 07:50 AM
VAG Error Code: 17132
EOBD II Error Code: P0748
Fault Location:
Solenoid Valve 6 (N93) 'F' - Open Circuit/Short Circuit to Earth
Possible Cause:
Transmission shift shock.
Fuse(s).
Wiring/Connector(s) from/to Solenoid Valve 6 (N93) 'F'.
Low transmission fluid level.
Dirty transmission fluid.
Solenoid Valve 6 (N93) 'F' faulty.
Torque converter clutch (TCC) solenoid.
Engine Control Module (ECM)/Powertrain Control Module (PCM)/Transmission Control Module (TCM) (J217).
Possible Solutions:
Check/Replace Fuse(s).
Check/Replace all faulty Wiring/Connector(s) from/to Solenoid Valve 6 (N93) 'F'.
Check/Replace Solenoid Valve 6 (N93) 'F'.
Perform Output Test.
When is the code detected?:
Engine Control Module (ECM) detects an open or shorted condition on the solenoid circuit.
Description:
The line solenoid valve regulates the oil pump discharge pressure to suit the driving condition in response to a signal sent from the Transmission Control Module (TCM).
As taken from my new https://volkswagenforum.com/forum/ge...oftware-34973/
Santa Albert
09-09-2013 01:24 PM
asvped
09-09-2012 04:53 AM
skutsko
04-11-2010 05:45 PM
keefamily
08-10-2009 12:50 PM
brebelle05
04-26-2009 01:58 PM
Quick Reply: please help PO748
