please help PO748
2004 Jetta we are getting a PO748 error code..... when we research it comes back the pressure solenoid .... can't find where that's located :confused:
VAG Error Code: 17132 EOBD II Error Code: P0748 Fault Location: Solenoid Valve 6 (N93) 'F' - Open Circuit/Short Circuit to Earth Possible Cause: Malfunction Indicator Lamp (MIL)(K83) active. Transmission shift shock. Fuse(s). Wiring/Connector(s) from/to Solenoid Valve 6 (N93) 'F'. Low transmission fluid level. Dirty transmission fluid. Solenoid Valve 6 (N93) 'F' faulty. Torque converter clutch (TCC) solenoid. Engine Control Module (ECM)/Powertrain Control Module (PCM)/Transmission Control Module (TCM) (J217). Possible Solutions: Check/Replace Fuse(s). Check/Replace all faulty Wiring/Connector(s) from/to Solenoid Valve 6 (N93) 'F'. Check/Replace Solenoid Valve 6 (N93) 'F'. Read Measuring Value Blocks (MVB). Perform Output Test. When is the code detected?: Engine Control Module (ECM) detects an open or shorted condition on the solenoid circuit. Description: The line solenoid valve regulates the oil pump discharge pressure to suit the driving condition in response to a signal sent from the Transmission Control Module (TCM). As taken from my new https://volkswagenforum.com/forum/ge...oftware-34973/ |
