performance
performance
i have a 96 vw jetta trek and am interested in doing the most i can to get the best performance out of it i am torn between going turbo or supercharger a buddy of mine said the 2.0l was set up to have turbo with the dished pistons but said there was some transmission upgrading i would have to do can anyone help me out and suggest what i could do to get the most out of my jetta thanks alot
RE: performance
You could do both. I've seen 2.0 super, but rather go turbo. You'll be fine as long as you don't run like 20 pounds of boost! Run like 8 or something and you'll be fine. Get a good cold air intake, good exhaust and you'll be fine.
RE: performance
I'm not sure as far as heads...I know the VR6 is dual cam, but not too sure about the other motors, they may be. I would to stick with Jetta-Jetta and Passat-Passat. Intermixing could cause unheard problems and be a waste of time.
