Transmission immobilizer & solenoid
Old 07-31-2016, 08:46 PM
John O'Donovan's Avatar
Default Transmission immobilizer & solenoid
SCANS ARE DOWN BELOW!!
Note:Used Ross Tech HEX-NET scanner .
Trying to figure out if the Immobilizer issue is related to the
transmission solenoid issue and if by some freak chance that the ABS code comes into play.
Do i have 3 separate issues to work on or is one causing all three?
After replacing all coolant hoses ,steering pump reservoir hose, water pump, oil cooler , trans oil cooler and seals, differential oil breather cap, filled differential with trans fluid (based on BENTLEY'S advice) transmission oil pan cover and side cover, throttle body (drive by cable) cleaning and adjustment. Also drained all fluids including coolant (G) engine oil and transmission oil ( filled in proper manner at proper temp etc).
Also replaced all fuel injectors and alternator
One other factor, I removed G68 Sensor, the one on the right (broke it on removal) but I'm not sure if I replaced it with the correct replacement sensor since G38 and G68 look identical so I may have purchased a second G38 instead of a G68 .I can't see any difference in the markings on the sensor
THE PROBLEM! THE PROBLEM
Transmission was working fine prior to all of this work but after I started the car up ,rolled it out of my garage , I put it into DRIVE/ 1st,2nd & 3rd gear it barely hopped forward and then cut out after taking my foot off of the gas. Now a solenoid code came up (N94 Valve 7)after the scan that followed my attempting to drive it .This was followed by another additional intermittent solenoid code (N88 Valve 1) in another attempt to drive it.
So I just don't have a clue as to what my plan of action at this point should be.
I'm attaching just a couple of these scans, one from the 29th with no immobilizer issues and one from the following day with an immobilizer issue P1570
So any thoughts will be appreciated .Thanks Guys & Gals
Here are 2 scans one day after the other. PS the immobilizer issue never appeared three months ago in 8 scans ( just thought I'd mention it)
Friday,29,July,2016,13:36:17:42100
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.4.1 (x64)
VIN: XXXXXXXXXXXXXXXXX License Plate:
Chassis Type: XX (1V - VW Golf Cabrio (1997 > 2002))
Scan: 01 02 03 08 15 25 35 56
Address 01: Engine Labels: 037-906-018-ABA.lbl
Part No: 037 906 018 H
Component: 2.0l R4/2V MOTR AT V04
Coding: 00003
Shop #: WSC 00066
VCID: 1A78196F843BCDEE90-4B3C
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 LA
Component: AG4 Getriebe 01M 4899
Coding: 00000
Shop #: WSC 00000
VCID: 7AB839EF647B2DEE30-0964
1 Fault Found:
00811 - System Not Ready for Interrogation (Ross-Tech; Check Fault Codes Later)
35-00 - -
Address 03: ABS Brakes Labels: 3A0-907-379.lbl
Part No: 3A0 907 379 D
Component: ABS ITTAE 20 GI V00
Coding: 03704
Shop #: WSC 00000
VCID: 2B16CCABDBA14466FB-4AC2
Address 25: Immobilizer Labels: 6X0-953-257.lbl
Part No: 6X0 953 257
Component: IMMO 0008
Coding: 00001
Shop #: WSC 40629
VCID: 7DB232F375551AD615-4B3C
XXXXXXXXXXXXXXXXX VWZ1Z0A1666169
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1JM 035 157 A
Component: Radio DE2 0005
Coding: 07403
Shop #: WSC 09144
VCID: 3E30F5FF38D3C1CE4C-51F2
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End-------------------------(Elapsed Time: 02:22)--------------------------
SECOND SCAN
Saturday,30,July,2016,14:52:46:42100
Data version: 20160216
Coding: 00003
Shop #: WSC 00066
VCID: 9A78996F043B4DEE10-4B3C
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
VCID: FAB8B9EFE47BADEEB0-0964
2 Faults Found:
00258 - Solenoid Valve 1 (N88)
36-10 - Open Circuit - Intermittent
00270 - Solenoid Valve 7 (N94)
Component: ABS ITTAE 20 GI V00 Coding: 03704
Shop #: WSC 00000
VCID: AB164CAB5BA1C4667B-4AC2
2 Faults Found:
01276 - ABS Hydraulic Pump (V64)
16-00 - Signal Outside Specifications
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
35-10 - - - Intermittent
Coding: 00001
Shop #: WSC 40629
VCID: FDB2B2F3F5559AD695-4B3C
Coding: 07403
Shop #: WSC 09144
VCID: BE3075FFB8D341CECC-51F2
1 Fault Found:
End-------------------------(Elapsed Time: 02:41)--------------------------
So that's it , I'm dying to hear the responses.
And by the way, i have thoroughly inspected and cleaned all wire connections under the battery tray (i removed it) and cleaned out the connectors on top of the transmission
Thanks again
Old 08-02-2016, 05:57 AM
Welcome to the forum John.
All these codes are shown on Category:Fault Codes - Ross-Tech Wiki if you search.
Or my https://volkswagenforum.com/forum/ge...oftware-34973/
If you have a Ross Tech HEX-NET scanner I would suggest you register it then you can join the Ross-Tech forum. You can ask about your problems along with posting a full AutoScan.
Old 08-02-2016, 06:31 AM
Hi Keith thanks for the respons. To answer your question , ya I'm aware of all that you said and I've done all of that. I can look uip the codes but that doesn't give opinions of what might be going on given the other info . Also, not that it should matter but I'd rather get my info here if that's ok.
So anyhow , do you have any suggestions what might be going on.?
Old 08-03-2016, 05:21 AM
So you have joined the Ross-Tech forum and posted your problem?
Old 08-03-2016, 08:26 AM
That is correct, many months ago. Is that a problem? I 'm not hearing any feedback to my posted problem . Is there something you'd like to say?
Old 08-04-2016, 06:50 AM
Do you have the same username on there?
  #7
Old 08-04-2016, 09:29 AM
Default reply
Keith you have asked 2 seemingly irrelevant questions to my automobile problem so far and I'm starting to wonder that maybe I misunderstand what a forum is all about. Is there a non beating around the bush question or statement you'd like to ask or make. Please do so and maybe them we can get on with what I came here for.
Very strange behaviour!
  #8
Old 08-06-2016, 06:52 AM
To me these aren't irrelevant questions if you have a Ross Tech HEX-NET scanner and can't sort your problem out you ask the maker.
Other than that you Google.
cabriojoe
04-27-2014 04:46 PM
Dar Var
11-14-2012 03:11 AM
whitewolf8
02-11-2009 02:55 PM
bjackt
07-22-2006 08:58 PM
exojj
02-04-2006 08:58 PM
Quick Reply: Transmission immobilizer & solenoid
