Transmission immobilizer & solenoid
SCANS ARE DOWN BELOW!!
Note:Used Ross Tech HEX-NET scanner . Trying to figure out if the Immobilizer issue is related to the transmission solenoid issue and if by some freak chance that the ABS code comes into play. Do i have 3 separate issues to work on or is one causing all three?:confused: After replacing all coolant hoses ,steering pump reservoir hose, water pump, oil cooler , trans oil cooler and seals, differential oil breather cap, filled differential with trans fluid (based on BENTLEY'S advice) transmission oil pan cover and side cover, throttle body (drive by cable) cleaning and adjustment. Also drained all fluids including coolant (G) engine oil and transmission oil ( filled in proper manner at proper temp etc). Also replaced all fuel injectors and alternator One other factor, I removed G68 Sensor, the one on the right (broke it on removal) but I'm not sure if I replaced it with the correct replacement sensor since G38 and G68 look identical so I may have purchased a second G38 instead of a G68 .I can't see any difference in the markings on the sensor THE PROBLEM! THE PROBLEM Transmission was working fine prior to all of this work but after I started the car up ,rolled it out of my garage , I put it into DRIVE/ 1st,2nd & 3rd gear it barely hopped forward and then cut out after taking my foot off of the gas. Now a solenoid code came up (N94 Valve 7)after the scan that followed my attempting to drive it .This was followed by another additional intermittent solenoid code (N88 Valve 1) in another attempt to drive it. So I just don't have a clue as to what my plan of action at this point should be. I'm attaching just a couple of these scans, one from the 29th with no immobilizer issues and one from the following day with an immobilizer issue P1570 So any thoughts will be appreciated .Thanks Guys & Gals Here are 2 scans one day after the other. PS the immobilizer issue never appeared three months ago in 8 scans ( just thought I'd mention it) Friday,29,July,2016,13:36:17:42100 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 15.7.4.1 (x64) VIN: XXXXXXXXXXXXXXXXX License Plate: Chassis Type: XX (1V - VW Golf Cabrio (1997 > 2002)) Scan: 01 02 03 08 15 25 35 56 VIN: XXXXXXXXXXXXXXXXX ------------------------------------------------------------------------------- Address 01: Engine Labels: 037-906-018-ABA.lbl Part No: 037 906 018 H Component: 2.0l R4/2V MOTR AT V04 Coding: 00003 Shop #: WSC 00066 VCID: 1A78196F843BCDEE90-4B3C No fault code found. Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01M-927-733.lbl Part No: 01M 927 733 LA Component: AG4 Getriebe 01M 4899 Coding: 00000 Shop #: WSC 00000 VCID: 7AB839EF647B2DEE30-0964 1 Fault Found: 00811 - System Not Ready for Interrogation (Ross-Tech; Check Fault Codes Later) 35-00 - - ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3A0-907-379.lbl Part No: 3A0 907 379 D Component: ABS ITTAE 20 GI V00 Coding: 03704 Shop #: WSC 00000 VCID: 2B16CCABDBA14466FB-4AC2 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 6X0-953-257.lbl Part No: 6X0 953 257 Component: IMMO 0008 Coding: 00001 Shop #: WSC 40629 VCID: 7DB232F375551AD615-4B3C XXXXXXXXXXXXXXXXX VWZ1Z0A1666169 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1J0-035-18x-56.lbl Part No: 1JM 035 157 A Component: Radio DE2 0005 Coding: 07403 Shop #: WSC 09144 VCID: 3E30F5FF38D3C1CE4C-51F2 1 Fault Found: 00856 - Radio Antenna 36-00 - Open Circuit End-------------------------(Elapsed Time: 02:22)-------------------------- SECOND SCAN Saturday,30,July,2016,14:52:46:42100 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 15.7.4.1 (x64) Data version: 20160216 VIN: XXXXXXXXXXXXXXXXX License Plate: Chassis Type: XX (1V - VW Golf Cabrio (1997 > 2002)) Scan: 01 02 03 08 15 25 35 56 VIN: XXXXXXXXXXXXXXXXX ------------------------------------------------------------------------------- Address 01: Engine Labels: 037-906-018-ABA.lbl Part No: 037 906 018 H Component: 2.0l R4/2V MOTR AT V04 Coding: 00003 Shop #: WSC 00066 VCID: 9A78996F043B4DEE10-4B3C 1 Fault Found: 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - Intermittent Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01M-927-733.lbl Part No: 01M 927 733 LA VCID: FAB8B9EFE47BADEEB0-0964 2 Faults Found: 00258 - Solenoid Valve 1 (N88) 36-10 - Open Circuit - Intermittent 00270 - Solenoid Valve 7 (N94) 36-00 - Open Circuit ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3A0-907-379.lbl Part No: 3A0 907 379 D Component: ABS ITTAE 20 GI V00 Coding: 03704 Shop #: WSC 00000 VCID: AB164CAB5BA1C4667B-4AC2 2 Faults Found: 01276 - ABS Hydraulic Pump (V64) 16-00 - Signal Outside Specifications 00287 - ABS Wheel Speed Sensor; Rear Right (G44) 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 6X0-953-257.lbl Part No: 6X0 953 257 Component: IMMO 0008 Coding: 00001 Shop #: WSC 40629 VCID: FDB2B2F3F5559AD695-4B3C XXXXXXXXXXXXXXXXX VWZ1Z0A1666169 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1J0-035-18x-56.lbl Part No: 1JM 035 157 A Component: Radio DE2 0005 Coding: 07403 Shop #: WSC 09144 VCID: BE3075FFB8D341CECC-51F2 1 Fault Found: 00856 - Radio Antenna 36-00 - Open Circuit End-------------------------(Elapsed Time: 02:41)-------------------------- So that's it , I'm dying to hear the responses. And by the way, i have thoroughly inspected and cleaned all wire connections under the battery tray (i removed it) and cleaned out the connectors on top of the transmission Thanks again |
Welcome to the forum John. http://i10.photobucket.com/albums/a1.../VWwelcome.gif
All these codes are shown on Category:Fault Codes - Ross-Tech Wiki if you search. Or my https://volkswagenforum.com/forum/ge...oftware-34973/ If you have a Ross Tech HEX-NET scanner I would suggest you register it then you can join the Ross-Tech forum. You can ask about your problems along with posting a full AutoScan. https://volkswagenforum.com/forum/ne...gnature-34185/ |
Hi Keith thanks for the respons. To answer your question , ya I'm aware of all that you said and I've done all of that. I can look uip the codes but that doesn't give opinions of what might be going on given the other info . Also, not that it should matter but I'd rather get my info here if that's ok.
So anyhow , do you have any suggestions what might be going on.? |
So you have joined the Ross-Tech forum and posted your problem?
That is correct, many months ago. Is that a problem? I 'm not hearing any feedback to my posted problem . Is there something you'd like to say?
Do you have the same username on there?
reply
Keith you have asked 2 seemingly irrelevant questions to my automobile problem so far and I'm starting to wonder that maybe I misunderstand what a forum is all about. Is there a non beating around the bush question or statement you'd like to ask or make. Please do so and maybe them we can get on with what I came here for.
Very strange behaviour! |
To me these aren't irrelevant questions if you have a Ross Tech HEX-NET scanner and can't sort your problem out you ask the maker.
Other than that you Google. |
