control pressure regulator
Old 08-29-2012, 04:10 PM
amalent's Avatar
Default control pressure regulator
As a follow up to my post about my cabriolet not running. Now will run after bleeding the lines but as soon as the radiator fan turns on when the engine is hot the regulator gets hot and the engine quits. As soon as I pour water on the regulator attached to the block next to the distributor and get it cooled down the engine runs and purrs again until the fan blows hot air onto it and heats it up again. So for sure the regulator is bad but why would getting it hot make it not work? Robert
Old 08-29-2012, 05:06 PM
You haven't read what you posted before have you? https://volkswagenforum.com/forum/vo...roblems-35077/
What part are you refering to as control pressure regulator are you talking about the fan switch?
idower
02-20-2008 04:58 PM
waterboxer2.1
09-23-2007 01:36 PM
standupguy
05-08-2007 07:02 AM
vwENFORCER
10-26-2006 03:04 PM
250psd
04-05-2006 07:02 PM
Quick Reply: control pressure regulator
