VWF Help & Suggestion Center Need help with VWF? Ask. Have a suggestion to better VWF? Tell us here.
Worth Shipping to Europe
Old Oct 28, 2019 | 12:27 PM
mreboni's Avatar
Question Worth Shipping to Europe
I have a 2017 Golf Alltrack (18K miles) which I am considering to ship to Italy indefinitely. Purchased in the US, but apparently built in Mexico. Can anyone suggest if it's worth shipping to Italy and what modifications would have to be made? Shipping costs are reasonable, but I cant seem to get the details from the dealer here, and figured what better place to ask than here! Surely someone here would have some suggestions.
Old Oct 29, 2019 | 10:01 AM
You have to make your own decision whether you want to import this Alltrack after a test drive.
Which engine size/type is fitted?
Manufacturer: VW, Date(s) Used: 06/2014-, Model: Golf Alltrack, Engine Code: CXBB, 125Kw, 170PS, 1.8 Ltr, 4 Cyls, Remarks: North American Region (NAR): Turbo Fuel Stratified Injection (TFSI)
Manufacturer: VW, Date(s) Used: 04/2015-, Model: Golf Alltrack, Engine Code: CJSB, 132Kw, 180PS, 1.8 Ltr, 4 Cyls, Remarks: Turbo Fuel Stratified Injection (TFSI) Chain
Manufacturer: VW, Date(s) Used: 12/2014-, Model: Golf Alltrack BlueMotion, Engine Code: CXXB, 81Kw, 110PS, 1.6 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) Timing belt
Manufacturer: VW, Date(s) Used: 12/2014-, Model: Golf Alltrack Variant, Engine Code: CUNA, 135Kw, 184PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) Timing belt
Old Oct 29, 2019 | 07:26 PM
mreboni's Avatar
Keithuk, I had thought of going through introductions, but saw that someone had asked the same question and never got a reply. In respose to your question, these are the tech specs I pulled up..... Not sure if they help.
Tech Specs
Vehicle Name
Volkswagen Golf Alltrack
Body Style
4MOTION
Drivetrain
All Wheel Drive
EPA Classification
Small Station Wagon
Passenger Capacity
5 5.0 min 5.0 max
Passenger Volume
94.3 ft3 94.3 min 94.3 max
Base Curb Weight
3395 lbs 3395.0 min 3395.0 max
Fuel Economy Est-Combined
25 25.0 min 25.0 max
EPA Fuel Economy Est - City
22 MPG 22.0 min 22.0 max
EPA Fuel Economy Est - Hwy
30 MPG 30.0 min 30.0 max
Engine Type
Intercooled Turbo Regular Unleaded I-4
Displacement
1.8 L/110
Fuel System
Gasoline Direct Injection
SAE Net Horsepower @ RPM
170 @ 4500
SAE Net Torque @ RPM
199 @ 1600
Trans Type
6 6.0 min 6.0 max
Trans Description Cont.
Auto-Shift Manual w/OD
First Gear Ratio (:1)
3.46 3.46 min 3.46 max
Second Gear Ratio (:1)
2.05 2.05 min 2.05 max
Third Gear Ratio (:1)
1.30 1.3 min 1.3 max
Fourth Gear Ratio (:1)
0.90 0.9 min 0.9 max
Fifth Gear Ratio (:1)
0.91 0.91 min 0.91 max
Sixth Gear Ratio (:1)
0.76 0.76 min 0.76 max
Reverse Ratio (:1)
3.99 3.99 min 3.99 max
Final Drive Axle Ratio (:1)
4.38 4.38 min 4.38 max
Cold Cranking Amps @ 0° F (Primary)
480 480.0 min 480.0 max
Tons/yr of CO2 Emissions @ 15K mi/year
7.1 7.1 min 7.1 max
Maximum Alternator Capacity (amps)
140 140.0 min 140.0 max
Suspension Type - Front
Strut
Suspension Type - Rear
Multi-Link
Suspension Type - Front (Cont.)
Strut
Suspension Type - Rear (Cont.)
Multi-Link
Front Tire Size
P205/55HR17
Rear Tire Size
P205/55HR17
Spare Tire Size
Compact
Front Wheel Size
17X7 in
Rear Wheel Size
17X7 in
Spare Wheel Size
Compact in
Front Wheel Material
Aluminum
Rear Wheel Material
Aluminum
Spare Wheel Material
Steel
Steering Type
Rack-Pinion
Turning Diameter - Curb to Curb
35.8 ft 35.8 min 35.8 max
Brake Type
4-Wheel Disc
Brake ABS System
4-Wheel
Disc - Front (Yes or )
Yes
Disc - Rear (Yes or )
Yes
Front Brake Rotor Diam x Thickness
11.3 in 11.3 min 11.3 max
Rear Brake Rotor Diam x Thickness
10.7 in 10.7 min 10.7 max
Fuel Tank Capacity, Approx
14.5 gal 14.5 min 14.5 max
Front Head Room
38.6 in 38.6 min 38.6 max
Front Leg Room
41.2 in 41.2 min 41.2 max
Front Shoulder Room
55.9 in 55.9 min 55.9 max
Second Head Room
Second Leg Room
35.6 in 35.6 min 35.6 max
Second Shoulder Room
53.9 in 53.9 min 53.9 max
Wheelbase
103.5 in 103.5 min 103.5 max
Length, Overall
180.2 in 180.2 min 180.2 max
Width, Max w/o mirrors
70.8 in 70.8 min 70.8 max
Height, Overall
59.6 in 59.6 min 59.6 max
Track Width, Front
60.9 in 60.9 min 60.9 max
Track Width, Rear
59.7 in 59.7 min 59.7 max
Min Ground Clearance
6.9 in 6.9 min 6.9 max
Cargo Volume to Seat 1
66.5 ft3 66.5 min 66.5 max
Cargo Volume to Seat 2
30.4 ft3 30.4 min 30.4 max
Cargo Volume to Seat 3
Engine Displacement Units
1.8 1.8 min 1.8 max
Engine Camshaft
DOHC
Engine Block Type
iron
Engine Cylinder Count
4 4.0 min 4.0 max
Engine Valve Count
4 4.0 min 4.0 max
Country of Origin
Mexico Volkswagen Passenger Car
carcaveman
Oct 19, 2019 11:58 AM
CDRYBR1
Feb 22, 2019 08:25 AM
PPG
May 18, 2018 11:02 AM
Jim T
Dec 22, 2017 05:46 AM
65VDub
Apr 2, 2009 01:27 AM
