SHARAN STRUT BEARING
Old Feb 10, 2006 | 12:43 PM
mdmilla1's Avatar
Default SHARAN STRUT BEARING
HI HAVE PLACED POSTS IN OTHER FORUMS BUT NO LUCK YET, AM TRYING TO FIND SOME HELP WITH REPLACING A SUSPENSION TOP STRUT BEARING ON A VOLKSWAGEN SHARAN S REG 2L? ANY HELP WOULD BE VERY APPRECIATED AND VERY WELCOME.
Old Jun 8, 2006 | 06:04 PM
stv fox's Avatar
Default RE: SHARAN STRUT BEARING
get a book the top strut bearing is a bit tricky you need to remove the susspention from the nuckel ball joint tie rod end axel bolt you need big tools and a fair amount of time and could dammage above mentioned parts which you might consider changing if the bearing is worn out so might they be also the weel bearing is accesable you need a press for that.it is a big job with lots of obsticals have a freind have tools have patiance take it to a trusted shp for a quote.
Andie12866
Mar 31, 2009 09:26 AM
zander
May 19, 2008 07:47 AM
guilly
Jan 22, 2008 05:49 PM
01vdub
Mar 25, 2007 10:47 PM
rundawg
Jan 31, 2007 02:31 PM
