SHARAN STRUT BEARING
HI HAVE PLACED POSTS IN OTHER FORUMS BUT NO LUCK YET, AM TRYING TO FIND SOME HELP WITH REPLACING A SUSPENSION TOP STRUT BEARING ON A VOLKSWAGEN SHARAN S REG 2L? ANY HELP WOULD BE VERY APPRECIATED AND VERY WELCOME.
RE: SHARAN STRUT BEARING
get a book the top strut bearing is a bit tricky you need to remove the susspention from the nuckel ball joint tie rod end axel bolt you need big tools and a fair amount of time and could dammage above mentioned parts which you might consider changing if the bearing is worn out so might they be also the weel bearing is accesable you need a press for that.it is a big job with lots of obsticals have a freind have tools have patiance take it to a trusted shp for a quote.
