Please help me identify this part!!
Hi,
I am not mechanically inclined and therefore need help from someone!!!
I recently purchased a 1984 VW Caddy 1300, that was beautifully restored.
I have one problem.......the reverse lights are not working!!!
It seems that a rather new gearbox was installed with the original motor. I am looking for the reverse light switch and came across this part:
It goes on top of the gearbox.
Could this be the reverse light switch? Or is it something else???
Thank you!!!
Enjoy the day wherever you are!!!
Thank you!!!
I wouldn't think so as I think its a 2 pin switch.
Switch for reversing light - 020 945 415 A - £15
Flat contact housing with gasket - 357 972 752 - £8.62
1 set single wires each with 2 contacts (in bag of 5, order quantity 5 - 000 979 133 - £2.58
Was dropped on 01/08/2009 for 000 979 133 X - £3.35
VOLKSWAGEN CADDY [CA] (SOUTH AFRICA) 1996: ELECTRICS: 94700. SWITCH - BRAKE LIGHT; SWITCH FOR REVERSING LIGHT; SOCKET; INTERIOR LIGHT; DOOR CONTACT SWITCH; TURN SIGNAL INDICATOR
Post moved to correct section.
alvafredsmith
Apr 20, 2009 02:48 AM
