A/C problems in Florida
Old 06-14-2018, 11:06 AM
katbo941's Avatar
Default A/C problems in Florida
Really hope someone is able to give me some advice. I have a 2009 Tiguan. The a/c worked, until it didn't. Was told by mechanic that it would cost $1300. to fix. Compressor, exp valve, some kind of dryer, flush and freon. I have no idea if this is a good deal. I have MS and cancer so the heat is killing me and have to get fixed. I won't even go into the gas door opening problem or the water that pours in from the carwash, lol. Was told all of these parts would have to be replaced due to the possibility of metal shavings from compressor. And, yes, I am that female that wants to believe. I could tear my 67 Mustang apart and put it back together, this is different animal. Thank you for any input.
Old 06-15-2018, 06:55 AM
Tglatt
12-30-2019 08:29 AM
Trtatywe28
09-27-2019 10:24 AM
curtis79
07-23-2019 08:39 AM
loggerman
03-01-2018 07:43 AM
Kevin Simon
12-28-2017 06:57 AM
Quick Reply: A/C problems in Florida
