Polo Mis-fire and Lumpy Idle
Old Jan 6, 2012 | 08:17 AM
Tall & Cool's Avatar
Unhappy Polo Mis-fire and Lumpy Idle
My engine mis-fires when idling for a minute or two, but only when the engine is hot. If I stop and re-start the engine, it runs fine again for another minute or two before mis-firing again. When driving, the engine runs perfectly fine and does not feel sluggish or anything. There are no start-up issues either.
Looking at the rev counter, it seems to drop (not suddenly) to around 700 RPM when the mis-fire happens.
The diagnostics I had done on the engine confirms an intermittent mis-fire on cylinder three (but does not say what the cause of the fault is). I have had the coils and spark plugs replaced, timing checked and all the engine wiring tested. A compression test has also been done and rules out a burned valve.
Before I had the coils replaced, the diagnostics reported an intermittent mis-fire on all three cylinders. Since the coils were replaced, the mis-fire is on cylinder three only.
The mechanic now believes that the fault could be with the ECU. He said that a faulty coil (before I had them replaced) could have sent a charge back to the ECU, causing damage.
I am just after some advice really before I spend more money! Any ideas?
Feb 4, 2011 11:44 PM
josajojosa
Apr 20, 2009 05:31 PM
gloftimmingblet97
Jan 31, 2008 09:37 PM
new beetle fire
Dec 13, 2007 05:11 AM
74HOOLIGAN
Sep 10, 2007 09:55 PM
