Polo Engine not Turning but it runs!???!?!?!? Bizzare and help needed
Old Jan 1, 2009 | 11:09 AM
VWpoloWV's Avatar
Default Polo Engine not Turning but it runs!???!?!?!? Bizzare and help needed
Hi I have a 1.0 litre polo (1999) model and I try to start the ignition but all the interior lights come on and the dash lights but the engine does not turn, it doesnt even make a noise. But as I had it towed home I cheekly tried to start the car and it came to life and I was able to drive home. As soon as i came home i tried to re-start the car and again i had the same problem, so i thought it may be the battery. As a final resort i tried jump leads and starting the car this way but this also did not turn the engine. So what could be the problem
thanks
Old Jan 1, 2009 | 11:43 AM
racerx002's Avatar
Default RE: Polo Engine not Turning but it runs!???!?!?!? Bizzare and help needed
Starter or starter solenoid if they are separate.
Old Jan 6, 2013 | 07:04 PM
stxrmxn's Avatar
I have the exact same problem. Have you managed to fix this? is there some kind of work around?
VW Polo will not turn over. All of a sudden 1 day will not start when the key is turned. All lights come on, will not start with jump leads. Turn the ignition and with the bonnet open i can hear a buzz for 2 seconds then a click and nothing. Car starts fine with a bump start.
mando
Oct 6, 2017 03:36 AM
tgavett
Sep 8, 2011 04:31 PM
tminor131
Jun 28, 2009 03:36 PM
tminor131
May 1, 2009 06:37 PM
msholmes
Jul 9, 2008 08:36 PM
