Polo 9N P0172 check engine + sometimes difficult to start
Old Aug 9, 2023 | 03:55 PM
Legly's Avatar
Default Polo 9N P0172 check engine + sometimes difficult to start
Hi everyone,
I have a problem with my car.
Information about my car:
VW Polo 1.2
Motor code: BMD
Year of manufacture: 2005
There is one error code in my car and that is P1072 (System Too Rich, Bank 1)
My fuel filter and fuel pump were also replaced last year. I also replaced the injector on the front cylinder this year.
I also have the following problem:
I have a problem starting the car. In all cases, I start the car with the clutch pressed in.
Sometimes it starts without a problem.
But sometimes it takes 15-20 minutes before it starts up with difficulty. In such cases, I have to play with the gas pedal.
Anyway, after starting the car I do not experience any abnormal operation.
The idle is normal.
There is perhaps a very minimal shudder, which is usually indicated by my wife, but I don't feel it.
Who has experienced such a mistake?
Can you suggest something to stop these problems?
Thank you very much!
Old Jul 29, 2024 | 08:29 AM
Ish's Avatar
Ish
Default Starting problems and P0172 code
Hi. Can anyone shed any light on this please?
I have same engine 2007 polo.
it takes about three attempts to start with throttle fully depressed. I can put the semi-automatic into gear on the third attempt without stalling, and then engine fires. It also throws up a P0172 code. Bank 1
too rich, and the engine runs rough at idle and in low revs
any help appreciated
hyb3rt
Jul 9, 2012 04:20 PM
Katiewatson
Dec 13, 2011 10:51 AM
Whitelipp
Jan 25, 2010 05:25 AM
tilleygoblin
Jan 21, 2010 04:27 AM
StewB
Jan 20, 2008 11:32 AM
