Please help! ABS light does not come on! bulp OK!. Polo Classic 1.6 1F 1997
Hello.
I have to get this fixed by tomorrow. The ABS light does not come on those two seconds when you turn on the ignition. The bulp(I changed it to be sure), the instrument, and the wire from the instrument and down to the fusebox all seem to work. But where does the connection go from the fuse box? What could be wrong? Some ABS control unit that does not give signal to the lamp? The fuses all work, and i have changed all the relays with ones from another car. Still does not come on. ABS system is working. |
| All times are GMT -5. The time now is 04:30 AM. |
