Window stops 1cm before top - regulator??
Hi
So i have a 1996 Passat and recently the drivers window has been acting up. It goes down no problem. When i put it up, it stops about 1cm before the top of the window frame and then makes a horrible grinding sound. Sounds like gears grinding.
If i grab the window with one hand on either side, i can pull it all the way to the top.
I pulled off the panel, and looked around but did not see anything obvious. I have a feeling that the issue is with the regulator, but i am looking for some other opinions to make sure.
Any thoughts?
thanks!!
Ian
Any thoughts?
thanks!!
Ian
pajeep
Dec 22, 2010 05:52 AM
gunner5360
Jul 13, 2008 09:44 PM
