Throwing coolant out of coolant reservoir
Old Nov 1, 2012 | 08:11 AM
Alex5357aa's Avatar
Default Throwing coolant out of coolant reservoir
Hi guys.Looks like i need your help because i can't figured out myself
So the story is i bought a 2004 vw passat with ( what we thought ) blowing head gasket because it was the milk shake in oil and coolant system.BUT I WANT TO NOTICE IT WASN'T OVERHEATING ! Its 1.8 Turbo 5 speed manual transmission passat. So my mechanic replaced the head gasket and i did an oil change with flush and coolant system flush.After that i drove it for about 25-30 miles and find out that its all the same problem.than the mechanic changed the oil cooler and i did change the oil with flush and oil.Afte i did and cooling system flush its start to overheating because coolant start throwing out of coolant reservoir.But no water in oil.No smokes or noises.No leaks.Just starting to throwing out a coolant from coolant reservoir.So please guy can you help me to find a reason why its throwing out coolant from coolant reservoir ? Thank you
Old Nov 1, 2012 | 08:14 AM
Alex5357aa's Avatar
Default Pics
Last edited by Alex5357aa; Nov 1, 2012 at 08:15 AM. Reason: Its after all pics.After car start overheating.
Old Nov 1, 2012 | 12:38 PM
They do suffer from head gasket problems depending on which engine you have.
Even if the head gasket was changed it depends if the cylinder head was inspected for cracks. Its still pushes coolant out of the expansion bottle the coolant appears to be over pressurised.
hbkidf
Jul 8, 2009 10:45 PM
cjcrider
Jan 1, 2008 03:15 PM
pookster71
Dec 12, 2007 03:09 PM
mandasue
Sep 4, 2007 09:27 PM
npasel
Apr 5, 2006 12:34 PM
