passat possible abs/brake fault?
Hi, I am a newbie, on my second passat http://www.vwforum.com/forums/images...icon_smile.gif and I do try to do my own fixes although help is always appreciated. Not sure I should put forward my problem here but I have a 2002 passat and I have just changed the n/s outer cv joint. since doing so I get a horrid brake noise judder http://www.vwforum.com/forums/images...s/confused.gif (from n/s front) only at low speed say pulling up at a junction. Also at around 60mph the car will hesitate at times and the traction warning light flicks on and off.http://www.vwforum.com/forums/images...s/confused.gif could this be the traction control applying the brake for some reason? I can correct this by accelerating or slowing down. Any ideas what I could of done. The reason for the joint change was a split boot which led to the joint problem. So alot of cv grease about. Could it be a dirty abs sensor? Thanks
