oil in coolant fluid – oil cooler ?
Hi!
My car: VW Passat B5 (1.9TDi AJM 85kW 1999) My problem: oil in coolant fluid http://img522.imageshack.us/img522/25/nadobka.th.jpg Possible causes: -head of the engine (head gasket was changed recently) -oil cooler Any other possibilities? So I detach oil cooler from the cooling system and clean coolant fluid. After few days I clean coolant fluid again (I guess rest of the oil which was circulating) and after that I did not find oil in coolant fluid anymore so I think problem was the oil cooler. Now I should replace it but I have little dilemma about finding the right one. See this picture – my oil cooler is on right: http://img402.imageshack.us/img402/7...hladice.th.jpg In online catalogues I can find both as recommended for my car. Even in ETKA catalogue is under passat schemes the left one: http://img69.imageshack.us/img69/624...anakres.th.jpg Is possible that both oil coolers are fitting into my passat? Here is one more picture from the Internet for comparison: http://img842.imageshack.us/img842/2...ceoleja.th.jpg[/quote] *my friend has left one in Golf IV and in my passat is that one in the middle |
Oil cooler replaced - I used same as was there before (with parallel leads).
I drove around 100km+ and no oil in coolant fluid and no oil losses from engine. Problem solved - broken oil cooler. |
