My Passat died... help!
Old Jun 10, 2011 | 09:00 AM
david1's Avatar
Angry My Passat died... help!
I recently purchased a 2004 Passat 1.8t with 146k miles on it and last night it died while driving about 25 mph through town. It has been running well except every once in a while when I get in the car it smells like gas and the check engine light came on the day before. It was running as normal and just died while driving so I coasted to the side of the road. When I try to restart it, it catches then idles pretty weakly and dies again. I need some help! What could this be? Is there something I can look for? Thanks!
Old Jul 1, 2011 | 04:25 PM
MASTERMAN's Avatar
Does it run rought like its misfireing? Remove the 4 coilpacs over the sparkplugs. inside ther are 4 connectors take a needlenose pliar and twist the 4 of them slightly. reassemble the car should run fine. you are getting a bad connection to the spark plug. Gas isnt being burned and that is what you smell good luck!
Dec 4, 2010 12:29 AM
RussT
Mar 28, 2010 11:37 AM
msilloh
Jun 9, 2009 01:36 PM
jdinpa
Feb 4, 2009 12:32 AM
ojready
May 18, 2006 04:15 PM
