inner door panel removal on 2006 passat
I have been unable to proceed with the front passenger door panel removal because I can't remove the door latch trim. Its hung up on the rear where the door latch is. I would like a complete set of instructions on how to remove the entire panel. Thanks! Tomt.
Thank you Keith. I have removed the panel tho I did break off two of the clips which I have repaired already. Now I am facing the secondary panel and I have removed the bolts holding it but it still doesnt want to come off. Something is holding it in the rear center area. What other stuff needs to be disconnected? I'm trying to punch out a dent in the lower part of the door. It is a 2006 passat. Thanks so much.
