high temp problem.
Old May 17, 2016 | 03:01 PM
bayo62's Avatar
Unhappy high temp problem.
Guys:
My car 2006 Passat, once I had to replace the two radiator fans (got a cheaper generic) that worked but seemed always staying on longer than it should after the engine is off. The other day a plastic piece of the front air intake (small cover) fell down and stopped the larger fan, I noticed something wrong because the temperature went up drastically; since then when I’m stuck in traffic the temp goes up and seems to me that the fans aren’t going as fast as before, is this possible? What could have happened?
Don’t want to take it to the dealership because I’m afraid it will cost me the value of this 10 year old car. Please help!!!!!!
Old May 18, 2016 | 06:31 AM
Its hard to say what's wrong over the web.
Old May 18, 2016 | 09:12 AM
bayo62's Avatar
Thank you I'll try to get and supply that info.
xzacattakx
Jul 3, 2009 12:46 AM
tgrill26
Aug 27, 2008 05:24 PM
flash087
Jul 7, 2006 02:12 PM
ultramagnus
Mar 8, 2006 02:48 AM
toedfe
Dec 22, 2005 01:43 PM
