Engine Vibration
Old Sep 30, 2007 | 01:17 PM
jcpsherdz's Avatar
Default Engine Vibration
Hi I'm new to the Forum,
My 01 VW Passat 1.8t started getting a vibration when in idle and in drive (at a Stop).
Took it to the dealer the replaced the motor mounts and the inter cooler $1800.00 later the vibration is still going strong.
I now think I'm starting to feel it at high speeds.
Can anybody help me get to the problem?
Thanks,
Joe
Old Oct 6, 2007 | 12:23 PM
jcpsherdz's Avatar
Default RE: Engine Vibration
Well by the looks of things I'm the only one with this problem!
They now tell me that I have carbon build up they replaced the MAS flow sensor?, and cleaned the Injectors? not sure what they really did, the car still has the vibration.
this site does not seem to be of any help!!!!!
Thanks,
Old Oct 6, 2007 | 09:11 PM
tbsavga's Avatar
Did they check the front mount? It's right in the front of the motor at the lower radiator support.
Can't imagine the intercooler having anything at all to do with a vibration.
The side motor mounts are filled with hydraulic oil, so when they blow, which will cause a vibration, which my 1.8t has as well.
Old Oct 16, 2007 | 07:09 PM
Jr's Avatar
Jr
Are you in NY, i have shop that only works on VW and Audi.
Old Oct 29, 2007 | 11:49 PM
emagdnim's Avatar
yeah, its got to be a motor mount. did they say why they replaced the intercooler? sounds like they got you on that one.
out of balance tire could cause vibration but you'd know whether or not it was a tire or your engine
Old May 17, 2009 | 01:15 PM
briandownunda's Avatar
Hi,
I have a 2002 1.8T passat, when I first start it up in the morning, I have no perceptible vibration, but after the car has warmed up a little, there is some vibration under moderate acceleration.
Is this, most likely, a motor mount ? If so, is the front mount the most likely culprit ?
Thanks in advance,
Brian
Old May 17, 2009 | 01:25 PM
  #7
racerx002's Avatar
Originally Posted by briandownunda
Hi,
Thanks in advance,
Brian
I would say you are exactly right. The front snub mount. Here is a good urethane one.
http://www.ecstuning.com/Volkswagen-...Engine/Mounts/
Old Oct 12, 2011 | 07:03 PM
  #8
afsoccerguy02's Avatar
Default 04 GLI vibration at idle
got an 04 GLI 1.8t and when im at idle, i feel the engine's vibration. I have changed the engine, and trans mount. I got under the car and noticed one bolt missing from the bottom of the turbo that goes into the down pipe to the muffler. Could that cause my vibration? car does not lose power at all or sounds like exhaust leaking. Any help?
charlieD
Jul 5, 2007 09:34 PM
Razzmaniac
Jun 7, 2007 09:42 PM
godoveryou
May 22, 2007 03:07 AM
godoveryou
May 15, 2007 07:30 AM
glynnd
Jan 21, 2006 03:48 PM
