Door Not Opening From the Inside
Old Jan 18, 2014 | 10:20 AM
irtzaali's Avatar
Unhappy Door Not Opening From the Inside
Hello I recently remover the interior door panel to install some speakers but unfortunately I wasn't able to. Now I have a new problem the driver's door won't open up from the inside but it opens up from the outside. How would I fix this problem? I have a 2003 VW Passat 1.8t. Thank You
Old Jan 23, 2014 | 06:39 PM
Vee Dub Ya's Avatar
Maybe you disconnected the linkage from the inner handle when you removed the inner panel, and forgot to reconnect it? Your car won't be the same as the following diagram, but should be similar. Make sure the rod (item 14) is connected on both ends. http://i33.tinypic.com/rvwz5t.jpg
Old Jan 23, 2014 | 07:41 PM
irtzaali's Avatar
I hooked that latch upto the door but it still doesn't open. Do you have any ideas why? Thanks
Tim Davis
Mar 27, 2012 09:40 AM
Castro27
Feb 5, 2009 07:52 PM
mricha
Jan 11, 2009 01:12 PM
demok
Aug 23, 2008 12:26 PM
demok
Jun 8, 2007 08:46 PM
