Central locking + water in passenger footwell
Old Nov 21, 2008 | 02:11 PM
benking's Avatar
Default Central locking + water in passenger footwell
Hi, im new here and a need a bit of help, my brother has just bought a 51plate 1.8 estate passat. There are a couple problems i need some help with.
The central lockng has stopped working since i took out and replace the battery. Would i be right in assuming that this would now need to be callibrated as the remote is still working but not doing anything. Does it need to be reprogramed by vw or is there a sequence i can do to recalibrate it???
Second problem is there is water coming in and has flooded the passenger footwell. Now before i start ripping the carpets up, has anyone else had this problem and could you advise on where to look first. Is this a common fault, as most non vw cars i have owned i know water eventually gets through the grommets.
Thank you and any help is appreciated
Ben
Old Nov 21, 2008 | 02:16 PM
Jrailer's Avatar
Default RE: Central locking + water in passenger footwell
might be the sunroof drains are pluged if it has a sunroof
Old Nov 22, 2008 | 02:56 PM
benking's Avatar
Any ideas on the central locking issue, ive sorted the leak
Old Nov 22, 2008 | 10:59 PM
Jrailer's Avatar
try this
you need two keys
have one in the key switch turnedto the on position but not running
put the other key in the door with it in the lock or unlock position hold down the lock botton on the remote
btw what was the leak?
Old Nov 23, 2008 | 06:02 AM
benking's Avatar
At first i thought it was the twopipes under the battery, it wasnt them. Then my brothers neighbour took all the glove box out and some other trim removed the carpet slightly.Pored water on the windscreen and water was pouring in from a small hole in the top left of the passenger footwell.
I need something to plug it now, any sudjestions????
huyuhy
Aug 9, 2011 04:35 AM
aidan
Jan 16, 2011 09:59 PM
gozzi
Aug 27, 2006 07:19 PM
smikes
Jul 16, 2006 10:07 AM
GDM200
Feb 18, 2006 03:02 AM
