99 Passat problem won't start
Old Oct 14, 2010 | 12:21 PM
foreignplus's Avatar
Smile 99 Passat problem won't start
1999 Passat 2.8L V6 AHA cranks all day long but won't start. I have no spark from coil to plugs and no fuel from pump to fuel rail. Which relay is causing this problem? Scanned ECU and no DTC's came up. HELP!
Old Nov 7, 2010 | 01:52 PM
elrocco88's Avatar
Sounds like the fuel pump relay is bad.
RELAY LOCATIONS
Relay location on the thirteen position auxiliary relay panel, above relay panel:
Thirteen Fold/Position Auxiliary Relay Panel
1 - Coolant Fan Control (FC) Relay (214) (a) 2 - Solar Cell Separation Relay 2 - Relay for Motor Remote Unlock Rear Lid (79) 3 - A/C Clutch Relay (267) 3 - A/C Cut-Off Control Module (384) 4 - A/C Cut-Off Control Module (384) 5 - Daytime running Lights Change-over Relay (173) 6 - Selector Lever Light Relay (205) 7 - Fog Light Relay (381) 7 - J9 - Rear Window Defogger Relay (381) 8 - Daytime Running Lights Change-over Relay (173) 8 - Control Unit Multifunction Steering Wheel (450) 9 - Control Unit Multifunction Steering Wheel (450) 10 - Brake Booster Relay (373) (569) 10 - Lamp Failure Control Module (373) 12 - Starting Interlock Relay (Alarm System) (185) (186) 13 - Starting Interlock Relay (204) 13 - Starting Interlock Relay (Clutch Position) (204) 13 - Starting Interlock Relay (Clutch System) (53) (a) Applies only to the following engines:
  • 1.8L AEB/AUG/ATW
  • 1.8L AWM with manual A/C control
  • 2.8L AHA with manual A/C control
  • 2.8L ATQ with manual A/C control (MY from 10/00)
Relay panel:
Relay Panel
1 - Dual Horn Relay (53) (204) 2 - Load Reduction Relay (213) 3 - Wiper/Washer Intermittent Relay (317) 4 - Fuel Pump (FP) Relay (208) (372) V - Wiper/Washer Intermittent Relay (377) VI - Wiper/Washer Intermittent Relay (377) Relay location on the eightfold auxiliary relay panel, behind relay panel:
Eight Fold/Position Relay Panel
mail4ajc
Apr 15, 2022 06:09 PM
Dec 4, 2010 12:29 AM
Jym
Aug 22, 2009 08:40 AM
wearyourtruth
Jan 2, 2009 01:29 PM
yellowvwthing
Apr 26, 2007 03:50 AM
